I am putting together a process for removing customfields from my JIRA environment in a safe, structured, and repeatable manner.
The process needs to:
So far, to facilitate the hiding of the customfields, I have been removing in-scope fields from screens however, I'm not sure if that covers it entirely.
In regards to detaching a customfield from configuration data ahead of deletion, the configuration items I have in-scope are:
Are there others I am missing that I should be checking?
Last but not least, I need this process to not be so cumbersome that I die of old age before I complete it.
Before someone mentions it, JQL CSV export doesn't support archived projects. It is consequently unhelpful unless I was to unarchive approximately 3000 projects bringing everything into the main index and lighting our instance on fire.
My process currently:
Any suggestions on how I can go about this or tips on making this process painless would be greatly appreciated.
I have database queries for filter and workflow usage.
Rewind can handle the backup for you, it provides ongoing daily backups with the ability to restore either the entire site or just single items
Check it out on the Atlassian Marketplace:
