While setting up JIRA locally, I accidentally reconfigured the URL and left out the "8080" port on the UI so the URL looked like http://<hostname>/
I tried to go to that URL, but it doesn't work at all. When I go back and try hostname:8080, I get an error from Tomcat that the resource is not available.
Since I cannot get back to the URL, I cannot set it back to the proper string. Is there a way to fix this outside of the URL?
Thanks for any suggestions.
I just re-installed the JIRA installation script, and it came right back - phew! Not sure that this was th best fix, but it did fix my problem.
Could you please tell me which script you reinstalled? Did you reinstall the entire program?
Saneth
