Hello Atlassian Community,
I have a product discovery roadmap with different stages. If the target reaches the respective date we enter the date when it did it. I need to generate a report with the history of the dates - how they changed and who changed them. Is this achievable?
Hi Bozhidar!
Good day to you! I'm Felipe from the ServiceRocket support team.
Regarding your question, unfortunately, Jira doesn’t have a built-in way to generate a historical report of date changes directly from the Product Discovery roadmap, but you can track these changes using the following methods:
You can set up an automation rule to capture date changes in a custom field or a comment:
This ensures you have a structured log of all changes moving forward.
If you need a more detailed report, you can use the Jira REST API:
I hope this helps.
Best,
Felipe
Hi there,
Thanks for the prompt answer!
The first option works just like a charm but I it is not exactly what I need. I will need to export a monthly or every three months a report with all the historical changes during that time. Exporting it to Confluence or in an excel will do.
Any suggestions further?
Thanks a lot!
Bozhidar
