We need a filter to have a list with all linked issues:
Something like:
project = "xx" AND issuetype = IR AND status changed TO 'CREATE PR' BY 'user1' AND issueLinkType = clones
The created PRs by user1 should be listed.
Anita
Hello @Anita Hütter
see here:
project = XXX AND issuetype = XXX AND issueLinkType = XXX AND status Changed To "XXX" BY 'Account Username'
for example:
project = DEMO AND issuetype = Story AND issueLinkType = clones AND status Changed To "In Progress" BY '5f1948face15e800269075b1'
Best Regards,
Ariel
Hi @Anita Hütter , you can't use JQL to find issues specifically transitioned by a specific user. However you can find issues updated by a specific user. So the following would be possible.
project = "xx" AND issuetype = IR AND Issuekey in updatedBy(user1) AND issueLinkType = clones
We configuered a status "create PR" with an all-transition to create a PR in another project. That is very helpful but to create a list PRs in projects xyz when you created it by this transition it seems to be impossible,
