I need help to edit the order of dashbaord
Fred Le Tran June 23, 2024
I want help to re order the two dimensional dashboard gadget of the x axis showing status, see below image.png
I want to re order the x axis to show status from Backlog, To do, to in Progress, testing, FL Blocked to Close in the proper sequence. Please Help :)
3 accepted
Damian Rosochacki
The gadget reflects the order they’re in on the Statuses page in the Admin section. You can reorder them, but it will impact all users (usually not a problem if you use any kind of logic in ordering them.)
Fred Le Tran June 24, 2024
Thanks @Damian Rosochacki can you please be more precise - where do I find the admin section, in the project section? or where else? this is workflow in the project setting Jira workflow issue2.JPG
Damian Rosochacki
Hey Fred,
You want to navigate to Admin > Issues > Statuses.
There, you’ll see a list of all statuses in Jira, and that’s the same list that the two dimensional gadget references for its status order.
The “system” Admin area does require Jira system admin rights - do you have that permission? If not, you’ll need to reach out to your Jira admin to assist you with this.
Like # people like this
Ravina
Hi @Fred Le Tran Welcome to the Atlassian community.
The sorting order of these status in two-dimensional gadget is set based on the global sorting order of the status, as in my below example it "IN PROGRESS", "RESOLVED", "TO DO"and so on, when I move the "TO DO" status above "RESOLVED" then the order is also changed on the gadget.
Please check the below attached screenshot for more details.
If you have a Jira administrator permission on your site you can change this order as per your requirement, but keep in mind that this is a global change and will reflect in all the places where statuses are used.
Before updating the status order
After moving "TO DO" status above the "RESOLVED" status
Please try and comment here in case of any issues.
Regards
Ravina
Thanks @Ravina But I can't fix my issue
Nicolas Grossi
Banned
June 23, 2024
Thank you @Nicolas Grossi However I am struggling to locate where I can edit the view of the workflow in my dashboard gadget - see belowJira workflow issue.JPG I created the above using the 2 dimensional filter and set x axis to issue type. The displayed issue type is illogical in that, from left to right should mirror my kanban columns ie Backlog, to do, in progress, FL blocked, testing, closed. Does that make sense to you? Right now, this gadget is very hard to read and not presentable. I need the urgent help of the community. I am company managed project. thoughts?
