I need help to set automation to copy value of deployed date field to Lead time ends field.
Agarwal Somya
July 20, 2023
I need help to set automation to copy value of deployed date field to Lead time ends field. I used the formula {{issue.deployed date.plusDays(1)}} to set the value but it fails.
Ash Yadav
Hi @Agarwal Somya welcome to the Atlassian Community!
Can you post a screenshot of your automation rule as it currently stands?
Also a screenshot of the audit log with the failure message would be quite helpful.
Kind Regards,
Ash
Agarwal Somya
July 20, 2023
Attached screenshot for reference. Unfortunately rule runs successfully but does not update the fields.no fields updated.PNGrule.PNG
