I need the Jelly script to create issues using custom fields
Sachin Ambulkar May 10, 2012
HI There,
I was trying to create the jelly script to import the issues in JIRA4.4.4 . in folowiing format. Please note that my project already have custom fields created i need to input data in it. I did follow the docs by atlassian but couldnt figure out much in this {
<jira:AddCustomFieldValue id="customfield_10000" value="field value"/>
<jira:AddCustomFieldValue name="Environment Select list" value="Windows XP"/>
Can some on ehelp me to understand what are above filed and since i lready have my customfields and their value exists , how can i use it in below example}
The script i am runing is below:
<jira:CreateIssue project-key="MFL" issueType="Bug" priority="3. Major" component="Design Link" versions="test" reporter="morety" summary="holes in the mesh on a specific model" created="2009-11-26 00:00:00" description="test description" Enviroment="Platform: Windows XP" issueKeyVar="keyvar"
<jira:AddCustomFieldValue name="Documentation Link" value="link://http:google.com"/> <jira:AddCustomFieldValue name="Issue Frequency" value="Always"/>
<jira:AddCustomFieldValue name="Platform" value="Windows XP x64,Windows 7 x64"/>
<jira:AddCustomFieldValue name="Build Number" value="Version: Not 2011Build: 09476-001"/>
<jira:AddCustomFieldValue name="Issue Source" value="QA"/>
<jira:AssignIssue key="${keyvar}" assignee="xyz" />
I hit some random error for which i couldnt find any help so far.
I would really appriciate if some can help me on this.
Thank You
Sachin
Renjith Pillai
May 14, 2012
Use the id instead of the name. (name says deprecated)
Renjith Pillai
May 14, 2012
  • Also priority seems to be wrong. Give only "Major"
  • You dont have a closing '>' tag for jira:CreateIssue
  • And I couldn't see the tag </jira:CreateIssue>
Sachin Ambulkar May 13, 2012
I am getting following error "java.io.IOException: expected '=', got 'j'
