I need to create 30 new components for my project. Rather than creating one by one is it possible to have them added via bulk update. If yes, how?
FYI - There are no issues / stories created in JIRA yet. Project is about to kick off and we need to have these components added before the project can kick-off.
Hi Saurav,
You can import bulk components into project with built in functionality called CSV import (Cloud) or CSV import (Server/DC)
You can check the following article for bulk component import:
https://confluence.atlassian.com/jirakb/how-to-bulk-import-components-into-jira-720418562.html
Something I noticed when using CSV Import to create new Components In Jira Cloud is that the import process reports a warning message, though it does create the new Components
HI Saurav,
See if this article helps you:
