I need to integrate JIRA with Azure DevOps with REST API using powershell
sivasankaran May 10, 2022
Can i get some sample script for this or any suggestion , Since i am new to this Field , it will be more helpful if somebody help me.
Syed Majid Hassan -Exalate-
June 15, 2022
Hi @sivasankaran ,
This is Majid @ Exalate.
If you are open to using an app to achieve your integration, I would urge you to look into Exalate to fully synchronize your Jira instance to Azure Devops bidirectionally. The app provides you fully customizable synchronization between work items in Azure Devops and Jira.
Please feel free to book a demo if you would like to see the product in action.
Majid
Diana_Architect_ZigiWave
@sivasankaran hi and welcome! have you thought of perhaps using external help. A tool like ZigiOps can help you connect the two systems in no time, bi-directionally, and sync any type of data. You can also customize it to fit your use cases. If interested, feel free to explore it. You can also book a demo if you want to see it in action.
Regards, Diana (ZigiWave)
Nic Brough -Adaptavist-
May 11, 2022
"Integrate" is a spectacularly meaningless word.
Could you tell us what you actually want to do?  How do you want the two systems to behave when they have been "integrated"?
sivasankaran May 11, 2022
Whenever a pipeline runs in DevOps , it should create a issue assigned to some assignee in JIRA. This is the requirement for now.
Especially the issue should be created when the pipeline "Fails"
May 11, 2022
OK, so you'll need to write some code to run when a pipleline fails - it should simply send a REST call over to Jira to create a new issue.
Like Volker Buschmann likes this
Yeah , You're right.
Sebastian Krzewiński
Hi @sivasankaran
Integration is a wide area. Could you be more specify what do you want achieve?
Seba
Like, i want to integrate the azure pipeline with jira
FREE
