I need to move issue from Service Desk project to a Jira project automatically
Anna Shvygar July 3, 2019
I need to move issue from Service Desk project to a particular  Jira project automatically. I am using Automation for Jira Plugin and JMWE. I can't quite figure out how to do it. Please help :)
David Fischer
With JMWE, you can't move an issue between projects. The reason is that moving issues is a very complicated undertaking, as it might require changing workflows, the current status, required fields, etc.
The recommended approach is to clone the issue into the new project (using the Create/Clone Issues post-function) and then optionally deleting the initial issue.
This worked perfectly for me. Thanks a lot! You saved me a lot of time and tears. Really appreciate it!
