I changed the workflow scheme of a Business Project and only the cards that were closed are being displayed in the board. All other statuses are empty.
Even though these same issues, with theses statuses that are mapped in the board, since it follows the workflow scheme, appear in other forms of visualization.
Exemple: "List” in screenshot #2.
Hey there,
I think the cause of this bad behavior its the limit of 1.000 cards per board.
As I've changed their closed status, they will appear again in the board, blocking the other status to be filled.
Anyone know if theres a way I can solve this manually?
One place you can check it the filter on the board. See if anything could of possibly filter the issue tickets .
-Ben
Hey @Benjamin
This is in a Business Project model. The board follow strictly what is declared in Workflow Scheme. I dont think there is a filter for the board.
If im wrong, please tell me where I can find it 😫
