I want an issue to move from project A to project B
khalid August 9, 2021
Hi team,
I have a requirement where I wanted an issue to move between projects
ex: I created an issue in project A workflow A and in some point I want it to jump to project B workflow B.
Thank you.
Manon Soubies-Camy
Hi @khalid,
I recommend to clone the issue to another project rather than moving it to another project. It is safer - you're sure to keep all information and everyone will still have access to the original issue.
You can create an automation rule to clone the issue to another project and then link the two issues:
Hope this helps,
- Manon
ill try this now and check if it works with my project
Aron Gombas _Midori_
Jira has a built-in feature in one of the drop-down menus, called "Move issue". It will every detail of the move, including workflow changes, field changes, etc.
I tried this, but I want it to move automatically in the workflow
Liam Green
August 9, 2021
Hi @khalid
Would you want to trigger a move automatically or do this manually?
in a certain step in project A workflow A I want to chose either to move to project B workflow B or C etc..
Liam Green
August 9, 2021
Hi @khalid
If you want the option to choose which project the issue is moved to, then I think you will need to do this manually using the 'move issue' function
khalid August 24, 2021
Hi @Liam Green , I would like to move it automatically not manual.
