×Hello,
I want to export the issue comment field to Excel using csv (current fields),Since CSV(all fields) option is disabled and not available.
wherein using csv(current fields), I have tried adding all the possible fields In columns by selecting comment, comments, feedback comments, run comments etc, but issue comment field is not able to export. Please do let me know the possibilities.
Thanks in advance
Hi @Abhi
I wonder why the export all fields (csv) option is disabled. Usually, if you select this option, then all comments are exported as well.
Hi @Abhi
Not possible with out plugins :(
See https://confluence.atlassian.com/jira/how-to-add-comments-to-excel-export-316113321.html
