I am using an administrator account to access the project. I have already set all the permissions for the account, yet I still cannot access the project.
Has anyone else experienced this issue and could help me?
Is it possible that the project was deleted? Check by clicking on the cog in upper right and choose Projects. Look in Trash and Archive in the sidebar. if you cannot access this area, then you will need to contact your organization administrator.
Also check if anyone can access the project. If no one can, then it likely has been deleted assuming it ever existed. If others can't access that it is a permissions issue and you will need to talk to a project/site/org administrator to give you access.
