Hi All,
I have the following problem: in IE9 you can edit the gadgets on the Dashboard only in Compatibility View. But in the case of creating/editing an issue you cannot select a dropdown list (e.g. Components) in Compatibility View but only in single view.
Do you know any settings which both feature is available in, without check/uncheck the Compatibility View button?
Best Regards,
Rumi
Yup, I've seen a similar problem. I recommend that you downgrade to IE8, it works with that. Or switch to Firefox, chrome.
At the same time you could create an issue in the Atlassian Jira Support. There they can give you a better tracking for this kind of issues.
