IE9 problem in JIRA 4.3.4
Rumceisz
Hi All,
I have the following problem: in IE9 you can edit the gadgets on the Dashboard only in Compatibility View. But in the case of creating/editing an issue you cannot select a dropdown list (e.g. Components) in Compatibility View but only in single view.
Do you know any settings which both feature is available in, without check/uncheck the Compatibility View button?
Best Regards,
Rumi
Jo-Anne MacLeod
April 11, 2012
Yup, I've seen a similar problem. I recommend that you downgrade to IE8, it works with that. Or switch to Firefox, chrome.
Ramiro P
April 11, 2012
At the same time you could create an issue in the Atlassian Jira Support. There they can give you a better tracking for this kind of issues.
