ISSUECHANGES table not visible in SQL for JIRA
John Kuhl
April 18, 2016
I have an end user trying to run a query using SQL for JIRA, she received the query with the help of Kinto Soft support. It references a table ISSUECHANGES for accessing issue history. That table doesn't appear to be present to me.
I am running JIRA Software version 6.2.1. I would appreciate any help.
John
Pablo Beltran
April 28, 2016
Upgrade please to the last available 2.0.3 version. Earlier versions use a weak process to create the database model and it stops if any unexpected error occurs causing missing tables. In the 2.0.3 version that process has been improved to be much more robust.
