×Today I have a project that I have setup with unique issue types and unique workflows per issue type. Part of the solution includes post functions in the Create transition to designate the assignee, again based upon Issue Type.
Now I am adding another business unit to the project that requires different assignees. Looking for ideas on how to accomplish.
so in the conceptual view below - If IssueType1 is opened for BU1 then Assignee = assignee1 if the Component = BU2 then Assignee = assignee6
There are a couple ways to tackle this. Is it required that both BUs co-exist in a single project? You could create a project for each BU and then this issue type / multiple component dependency would go away.
As another option, you could create components specific to a BU (append existing component with new BU name). For example: Component1-BU1 = assignee1, Component1-BU2 = assignee6.
A third option would be to automate this with something like Power Scripts for Jira. In which case you could set a script like this on the issue create transition post-function:
if(issueType=="issueType1" && component=="BU2") {
assignee="assignee6";
else if(issueType=="issueType2" && component=="BU1") {
assignee="assignee2";
Have you tried setting up components in JIRA named BU1, BU2 etc and then adding those assignees as the component leads? If you do that, you can modify the workflow post function to assign the issue to the component lead.
@Jobin Kuruvilla [Adaptavist], thanks for the response. However, if I only have two BUs (Components) but 10 different assignees that would not work? Stating the issue another way:
IssueType1 + BU1 --> Assignee = Fred
IssueType1 + BU2 --> Assignee = Sally
IssueType2 + BU1 --> Assignee = Betty
IssueType2 + BU2 --> Assignee = Salaji
etc...
I'm currently looking at different options to my assignee dilemma to see if I can simplify it.
Right. You can do with the automation plugin I guess. Assign the issue if it matches a JQL (based on your issuetype and BU).
Another option would be to have different workflows for each issuetype and then have different branches in the workflow based on BU. Each branch will then assign issues to a different user.
