So my Atlassian friends - is there any way to do this?
I am running a BackUp/Restore to a stage instance and I am missing 193 issues - identified by using the Site Statistics plugin.
How do I isolate those issues to figure out the problem?
TIA
The solution is to create a filter of the Project and then on a Dashboard add the "Filter Results" Gadget - add the filter to that and save.
Probably the question was about to identify the missing issues in the restore?
Could be due to below:
