Implementing Risk management in Portfolio for Jira
Dwaraka Karanam August 15, 2019
I intend implementing Risk Management on Jira. Would solicit recommendations for implementing Risk Management.
I am currently thinking of creating an Issue Type called Risk at Story level. I can include Risk Probability and Risk Consequence  custom fields and Use Labels to set ROAM attributes.
I can then link Risk to Stories as blockers thereby building that dependency.
I would appreciate any better ideas.
Thanks.
Craig Schwarze _ProjectBalm_
Hi Dwarkin,
I'd like to suggest our Risk Register tool. Using a pre-built tool will save you a lot of time!
https://marketplace.atlassian.com/apps/1213146/risk-register?hosting=cloud&tab=overview
Dwaraka Karanam August 19, 2019
Thanks for the recommendation Craig. I have downloaded the trial version to explore the tool.
Dwarakanath
