Import OnDemand Jira+Greenhopper Project into Jira Agile Downloaded version
POL Argentina March 2, 2014
Guys,
Im trying to import a project from Jira on demand (with Greenhopper plugin) into a new "JIRA Agile" downloaded intance, and Im getting the following errors:
The backup project 'XXX' requires custom field named 'Epic Colour' with full key 'com.pyxis.greenhopper.jira:gh-epic-color'. In the current instance of JIRA the plugin is at version '6.3.9', but in the backup it is at version '6.3.8.1'.
The backup project 'XXX' requires custom field named 'Epic Link' with full key 'com.pyxis.greenhopper.jira:gh-epic-link'. In the current instance of JIRA the plugin is at version '6.3.9', but in the backup it is at version '6.3.8.1'.
The backup project 'XXX' requires custom field named 'Epic Name' with full key 'com.pyxis.greenhopper.jira:gh-epic-label'. In the current instance of JIRA the plugin is at version '6.3.9', but in the backup it is at version '6.3.8.1'.
The backup project 'XXX' requires custom field named 'Epic Status' with full key 'com.pyxis.greenhopper.jira:gh-epic-status'. In the current instance of JIRA the plugin is at version '6.3.9', but in the backup it is at version '6.3.8.1'.
The backup project 'XXX' requires custom field named 'Rank' with full key 'com.pyxis.greenhopper.jira:gh-global-rank'. In the current instance of JIRA the plugin is at version '6.3.9', but in the backup it is at version '6.3.8.1'.
The backup project 'XXX' requires custom field named 'Release Version History' with full key 'com.pyxis.greenhopper.jira:greenhopper-releasedmultiversionhistory'. In the current instance of JIRA the plugin is at version '6.3.9', but in the backup it is at version '6.3.8.1'.
The backup project 'XXX' requires custom field named 'Sprint' with full key 'com.pyxis.greenhopper.jira:gh-sprint'. In the current instance of JIRA the plugin is at version '6.3.9', but in the backup it is at version '6.3.8.1'.
Is there any way I can import this project or both intances are incompatible?
Thanks in advance,
Karie Kelly
March 3, 2014
Have you tried uninstalling your current download Agile plugin and installing the version associated with 6.3.8.1?
