Import issue from CSV to custom fields issue
Ivan Kan
July 28, 2015
When I try to import the issue from CSV, with some custom fields with Value checking, during validation, it says that those issues will not be created due to errors.
When I check the warning, those warning are occur on the custom fields which had setup field value checking:
  • The value [ {null=''SIT(QA Testing)''} ] can't be added to the Custom Field [ Testing Phase ]. The value [ {null=''SIT(QA Testing)''} ] can't be found or is in the incorrect format
However, I am sure I can use the same value in that custom field.
How can I do on this case?
Ivan
pborkowski
September 14, 2015
Could you open a ticket in our official support: https://support.atlassian.com ? This issue seems to be hitting more of our customers and could be a possible bug. By reporting it as a support case we could quickly trace it provide you a possible workaround.
Arnab Sur
September 6, 2015
Hi .. I'm facing a similar issue ... can somebody help please?
Ivan Kan
July 29, 2015
I don't the field type. I capture the screen of the field here.
pborkowski
July 28, 2015
Could you share what type of Custom Field is not accepting your values?
