Good afternoon!
After I start importing the project using the plugin (project Configurator for Jira).
It freezes at startup, you can tell what to watch and why this is possible.
I'm attaching screenshots.
Can you tell me if jira versions should be the same?
@Ravi Sagar _Sparxsys_ Hi.
What magazine should I look at, can you tell me? there are a lot of them.
I looked at the atlassian-jira.log * there are no errors
