I'm moving Projects from one instance of JIRA to another using the Export/Import feature. When I import the Project onto the new instance, it correctly creates all of the issues but when I view the Agile Boards (e.g. Planning Board), the order that it displays the issues in is incorrect. I noticed that the Rank values are not the same. It looks like it reassigned a new Rank value during the import and they're not in the same sequence as the orignal. Is this a known issue? If so, is there a workaround to correct it?
I'm afraid that based on the following links, that functionality is not available at this time.
https://jira.atlassian.com/browse/JRA-28748
https://jira.atlassian.com/browse/JRA-28659
