×I would like to know the syntax for *.csv file for importing project where one issue/task is blocking (błocks) several other issue.
I was trying to add " task1,task1,task3" as an entry for the błocks column but it doesn't work.
Example
Id, description, label, blocks
Task1, this is task1,test,
Task2, this is task2,test,Task1,Task3
Task3,this is task2,test,
