Importing issues from excel to JIRA
Hemanth Kumar BH
August 6, 2013
We currently have a requirement where in we have bulk amount of issues tabulated in an excel file. Each row in excel has to be created as an issue in JIRA. Is there any sort of plugin or anything which would help us out? Currently we are manually creating issues and since the count of issues to be loaded into JIRA is increasing everyday, we are looking out for an issue importer.
Please guide us
Thank you.
7 votes
Udo Brand
August 6, 2013
I'm not sure if you can import a xls(x)-file, but you could use the csv-Importer. Please check the documentation
Hemanth Kumar BH
August 6, 2013
Thanks for thr reply Udo Brand.
I went through the documentation and proceeded as guided. I am able to import the issues from the excel to JIRA.
thanks again
Like Charles Kleczkowski likes this
Udo Brand
August 6, 2013
Glad I could help.
kumar Koppisetti February 22, 2015
could you please guide me.. how to import multiple issues from excel to JIRA
Udo Brand
February 23, 2015
3 votes
Janos Biro
Hi guys,
With JExcel  you can import issues from Excel using the usual Ctrl+C, Ctrl+V
https://marketplace.atlassian.com/plugins/com.moresimp.jexcel
I hope it helped,
Janos
Chuck Diewald June 19, 2017
Try Administration > System > External System Import > CSV to import data from Excel. I ran into some challenges with this, and documented my findings in a blog at Importing a project plan with subtasks from Excel into Jira
praga indrakumar
June 5, 2020
Is it possible to do an import of defects into JIRA without having admin privileges ? Any option alternative ?
Lewis Cook
December 2, 2019
Realise this is a pretty old request but for those that stumble back across it this is certainly now possible in the Admin area (server and cloud).
You are looking for a "External system import" which will allow you to map your excel columns to Jira fields etc.
Amit Anand
Is this possible to migrate transition history as well?
Lewis Cook
May 13, 2020
Hi Amit,
 Not that I am aware of, these are essentially newly created issues.
I've only every done fairly basic imports but I guess if you try it and see what the mapping options are you could potentially import additional detail such as comments or history. I would be surprised if you could though.
Lewis
Yogesh Mude[Jira]
January 3, 2017
Hi @Hemanth Kumar BH,
can u please help us here to import data from Excel format into jIra.
as u mentioned in ur above comment, you provide this documentation, but i went through this article here will find CSV to JIRA.
Rohan Chitre
October 8, 2014
Hello Hemanth,
Can you please explain how could you import from excel?
