Impossible to delete a workflow without workflow system
Benjamin CIOTTI August 20, 2014
I have two workflows linked with no workflow systems that I'd liked to delete.
But they are still considered as active. What could be causing that ?
Benjamin CIOTTI August 21, 2014
It seems to be OK now (I did the same modification on another workflow schemes and it put all the workflows in the proper active / inactive stats)
Here is what I did exactly :
Context :
- my workflow is a customed workflow (designed by us)
- it was used by one projet for on type of demand
Actions performed :
- we were not using this type of demand anymore, so I moved the demands to another type
- I removed the type of demand from the projet demand sheme
- I deleted this type of demand (there were no demand of this type anymore)
- During these operations, I did not modify the workflow scheme of the project
What I have after that
- the type of demand is not present anymore in the workflow scheme of the project (which is logical because I deleted the type of demand)
- the workflow is still there, linked to no worflow scheme but still considered as active (so I cannot delete it)
Thnak you for your anwers
I do not have any inactive workflow schemes.
And the workflow I want to delete is not linked to any workflow sheme either (on the workflow page, the colomn indicating which workflows shemes the workflow is linked to is empty)
Alexey_Rjeutski__Polontech_
August 21, 2014
Please check that those workflows do not participate in inactive workflow schemes. You should remove them from the workflow schemes first.
