In JIRA flag an Issue on Worklow change maybe with Checkbox
Thomas Hergenröder
March 28, 2012
I want to set a flag on an issue in JIRA on workflow transition.
It should also be possible to search for this flag.
I tried to use multiple checkboxes with only one checkbox, which gave me someting looking good.
But when I wanted to set the checkbox in a post function, I was not able to set it. I tried to use the JIRA Misc Workflow Extensions and the JIRA Workflow Toolbox plugins.
However I cannot find a solution.
Can anyone recomend a solution for me?
Jo-Anne MacLeod
March 28, 2012
The jira suite utilities has a post function that will allow you to "update issue custom field" and you can set a field value from there.
Thomas Hergenröder
March 29, 2012
The jira suite utilities from the post by Jo-Anne MacLeod did work.
In my case I had to set the multipe checkbox field with the string that my checkbox was named with.
The same plugin also allowed me to uncheck the checkbox
Radu Dumitriu
March 28, 2012
Try this one: https://plugins.atlassian.com/plugins/com.keplerrominfo.jira.plugins.jjupin (commercial)
On your workflow postfunction routine, it's just as simple as saying:
customfield_10001="myvalue";
For examples: http://confluence.kepler-rominfo.com/display/JJUP20/JJUPIN+Tutorials
