Hi team,
I've noticed that in Jira 8.4.0, when creating issues without verifying if a Custom Field is present in a Screen:
issueInputParameters.setSkipScreenCheck(true);
IssueService.CreateValidationResult result = issueService.validateCreate(user, issueInputParameters);
Jira is throwing an error due to ArchivedDateSystemField:
Not implementedjava.lang.UnsupportedOperationException: Not implemented
at com.atlassian.jira.issue.fields.ArchivedDateSystemField.getRelevantParams(ArchivedDateSystemField.java:54)
at com.atlassian.jira.issue.fields.AbstractOrderableField.populateFromParams(AbstractOrderableField.java:185)
at com.atlassian.jira.web.action.issue.IssueCreationHelperBeanImpl.validateCreateIssueFields(IssueCreationHelperBeanImpl.java:80)
at com.atlassian.jira.web.action.issue.IssueCreationHelperBeanImpl.validateCreateIssueFields(IssueCreationHelperBeanImpl.java:57)
at com.atlassian.jira.bc.issue.DefaultIssueService.validateAndCreateIssueFromFields(DefaultIssueService.java:782)
at com.atlassian.jira.bc.issue.DefaultIssueService.validateCreate(DefaultIssueService.java:742)
at com.atlassian.jira.bc.issue.DefaultIssueService.validateCreate(DefaultIssueService.java:202)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at com.atlassian.plugin.util.ContextClassLoaderSettingInvocationHandler.invoke(ContextClassLoaderSettingInvocationHandler.java:26)
at com.sun.proxy.$Proxy76.validateCreate(Unknown Source)
at com.atlassian.plugin.osgi.bridge.external.HostComponentFactoryBean$DynamicServiceInvocationHandler.invoke(HostComponentFactoryBean.java:131)
A workaround for this problem is to create the issue first, with the default:
issueInputParameters.setSkipScreenCheck(false);
and after updating the newly created issue with:
This problem only happens in Jira 8.4.0. I've tested and it works on 8.3.0, 8.4.1 and 8.5.0 eap 2.
Is anyone having the same issue?
Diamantino Campos
Apparently this will be fixed in the next release: https://jira.atlassian.com/browse/JRASERVER-69968
