We use these old issues and need to access them frequently. But they seem to be archived. I have looked and looked and cannot figure out how to set my board to NOT archive. Thanks!
Hello Michelle,
Please, check the documentation below to know how you can restore an archived project and the issues created on it:
thanks Petterson! I never archived the project. the stories/issues just aged out of my view. any other ideas?
Hello Michelle,
Thank you for your explanation.
Actually, it is a default behavior on Business board to hide issues after 14 days they are on the last column. Unfortunately, this behavior cannot be customized, so you will need to select the link at the bottom of this column to see them again.
You can vote for the feature request below:
For now, JIRA Core boards are simple features hard-coded that does not allow any kind of customization, so if you need to customize it I would recommend you to sign-up for JIRA Software so you can use the custom boards available for the application.
You are welcome, Michelle.
Please, feel free to accept my answer so it can help other customers and let them know where they can vote for this feature.
