In automation, create a link issue with subtasks in a branch
Duval_ Stéphanie
I created an automation task to do that :
when I create a ticket of type A with the field Card_type, I search all cards with this type and create a subtask for each of all. I would like for each subtask create a link (caused by) with the ticket of type A (triggerissue).
How I can do that. For the moment, I can only create a link between the cards and the trigger, but not between the subtask and the trigger.
2 accepted
Sergei Troshin
March 22, 2025
Hi @Duval_ Stéphanie and Welcome to Atlassian Community!
You can specify one more field—Linked Issues—in the Create Sub-task action, as @Bill Sheboy mentioned.
Here are some screenshots for better understanding:
Duval_ Stéphanie
Hi Sergei,
It's perfect, I didn't see it and it works fine !!
Thanks a lot !
Have a great day,
Stéphanie
Bill Sheboy
March 21, 2025
Hi @Duval_ Stéphanie -- Welcome to the Atlassian Community!
Rather than using the Link Issue action, you can add the link at the same time the sub-task is created:
  • delete your Link Issue action
  • in the Create Issue action, select the Linked Issues field from the dropdown
  • select your link type and the trigger issue
Duval_ Stéphanie
Thanks Bill for your answer !
It works fine !
Have a great day,
Stéphanie
Like Bill Sheboy likes this
