In backlog all closed issues are appearing first for active sprint , how to reorder it ?
Suvarna February 17, 2025
How to reorder sequence of Backlog issues as per the status
first new and open issues to be appear and then closed issues.
Stephen.Lugton
@Suvarna
If you order by statuscategory it will filter in the order 'To Do' (Grey), 'In Progress' (Blue) then 'Done' (Green):
order by statusCategory asc
Marc - Devoteam
February 17, 2025
Hi @Suvarna
Adjust the board filter to order the filter results by status.
It wil still be alphabetically.
By default board is ordered by rank.
filter is simple
project = xxx  ORDER BY cf[12404] DESC or project = xxx ORDER BY cf[12404] asc
used above tow ways still closed issues are appearing first
Marc - Devoteam
February 18, 2025
As I mentioned, results It wil still be alphabetically.
There is no option to group by a certain order.
Options are to use components or labels or even another custom field.
