Inactive groups in users and roles tool in project
krzysztofzarebski January 9, 2020
Does anyone know, what is this additional text Inactive? JS 8.6.0
2 accepted
Akmal Harith
March 5, 2020
Hi everyone, just to let you guys know that there is a bug which is affecting Jira Server 8.6.0 here:
This is not reproducible in Jira Server 8.6.1 though. Try to upgrade to any of our newer releases and see if the problem persists.
Best regards,
Akmal Harith | Atlassian Support
Thomas B
January 10, 2020
Hello @krzysztofzarebski - depends on how your user management is configured.
  • If you instance is managed by Active Directory, The (inactive) must be changed in the Active Directory manager & re-sync AD with Jira.
  • If your instance is managed by Jira User Management, you can change the (inactive) from Admin > User Management > {Find Username} > Edit > Check the Active Box.
There is a similar thread here that may be useful: https://community.atlassian.com/t5/Jira-questions/User-showing-as-Inactive/qaq-p/931877
Please let me know if this fixed your issue.
Thomas
krzysztofzarebski January 12, 2020
Hi Thomas,
Thank you for the answer. But it is still different case. We have manage users by AD, not the groups. We use LDAP Permissions: Read Only, with Local Groups. From other side, what's the impact by inactive users to a local groups. Becouse I have problem with inactive groups, not with inactive users.
Oleg Andreas
January 22, 2020
Hi i have the same Issue. Groups are market as Inactive. All users in this groups are active (Jira user Directory)
The Dashboards and KanbanBoard are not displayed.
Jira 8.6
Thx
krzysztofzarebski January 22, 2020
For me, it looks like a bug :o
Ben Campbell
We see the same thing.  Jira 8.6.0, using Okta for identity, we're also seeing inactive for groups.  seems like a bug to me.
