Hi Team,
I was configuring Application links with JIRA 7.1.4 with Confluence 5.9, i was having status incompatible once the link is made.
I have even done the outgoing and incoming authentication.
Note: I had also configured Confluence 5.9 with JIRA 7.0.0, there was no issue
Please kindly advice on the below.
Find attached screenshot
image2016-5-6 13:47:18.png
Hi Chris,
Even i have delete the links and recreate them, the issue is the same.
Can you let me know how to check version of Application Links??
Thanks.
Kind regards
Swarna
I've seen similar problems (in JIRA 6.x) where the AppLinks plugin in JIRA was incompatible with the Applinks plugin in Confluence. That might be what the Status indicator (Incompatible) is saying.
You could check the version of Application Links plugin in both instances and make sure they are compatible - I think there is a compatibility matrix in the docs somewhere.
Other than that I can only suggest deleting the links and recreating them.
Compatibility matrix is here, but the list of what is supposed to be incompatible is very small. Shouldn't be the issue according to the page. I'm also looking for other reasons why you could get this status.
HI Majken
Can you let me know how to verify for the version of application links for JIRA 7.1.4 and Confluence 5.9?
Regards
Swarna
Go to manage add-ons, in the filter pick system. There are a few components that will say Application Links, but they should all have the same version number.
Hi Majken
Thanks for your assistance. The issue has been solved out
Kind Regards,
Swarna
