×Error received when trying to transition certain tickets or even delete them
Log's referral number: 4faf5a6d-63d0-49f4-a4ed-8ca6809e1607
Referer URL:
com.atlassian.jira.index.IndexingFailureException: Indexing completed with 1 errors
com.atlassian.jira.index.IndexingFailureException: Indexing completed with 1 errors at com.atlassian.jira.index.AccumulatingResultBuilder$CompositeResult.await(AccumulatingResultBuilder.java:189) [classes/:?] at com.atlassian.jira.issue.index.DefaultIndexManager.obtain(DefaultIndexManager.java:863) [classes/:?] at com.atlassian.jira.issue.index.DefaultIndexManager.await(DefaultIndexManager.java:843) [classes/:?] at com.atlassian.jira.issue.index.DefaultIndexManager.executeWithIndexLock(DefaultIndexManager.java:830) [classes/:?] at com.atlassian.jira.issue.index.DefaultIndexManager.reIndexIssues(DefaultIndexManager.java:618) [classes/:?] at com.atlassian.jira.issue.index.DefaultIndexManager.reIndexIssueObjects(DefaultIndexManager.java:494) [classes/:?] at com.atlassian.jira.issue.index.DefaultIndexManager.reIndex(DefaultIndexManager.java:540) [classes/:?] at com.atlassian.jira.issue.index.DefaultIndexManager.reIndex(DefaultIndexManager.java:523) [classes/:?] at sun.reflect.GeneratedMethodAccessor2012.invoke(Unknown Source) [?:?] at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) [?:1.8.0_171] at java.lang.reflect.Method.invoke(Method.java:498) [?:1.8.0_171] at com.atlassian.jira.config.component.SwitchingInvocationHandler.invoke(SwitchingInvocationHandler.java:38) [classes/:?] at com.sun.proxy.$Proxy17.reIndex(Unknown Source) [?:?] at com.atlassian.jira.issue.link.DefaultIssueLinkManager.reindexLinkedIssues(DefaultIssueLinkManager.java:121) [classes/:?] at com.atlassian.jira.issue.link.DefaultIssueLinkManager.removeIssueLinkInternal(DefaultIssueLinkManager.java:194) [classes/:?] at com.atlassian.jira.issue.link.DefaultIssueLinkManager.deleteIssueLinksFromIssue(DefaultIssueLinkManager.java:261) [classes/:?] at com.atlassian.jira.issue.link.DefaultIssueLinkManager.removeIssueLinksInternal(DefaultIssueLinkManager.java:243) [classes/:?] at com.atlassian.jira.issue.link.DefaultIssueLinkManager.removeIssueLinksNoChangeItems(DefaultIssueLinkManager.java:230) [classes/:?] at com.atlassian.jira.issue.managers.DefaultIssueDeleteHelper.removeIssueLinks(DefaultIssueDeleteHelper.java:198) [classes/:?] at com.atlassian.jira.issue.managers.DefaultIssueDeleteHelper.deleteIssue(DefaultIssueDeleteHelper.java:145) [classes/:?] at com.atlassian.jira.issue.managers.DefaultIssueManager.deleteIssue(DefaultIssueManager.java:743) [classes/:?] at com.atlassian.jira.issue.managers.RequestCachingIssueManager.deleteIssue(RequestCachingIssueManager.java:247) [classes/:?] at com.atlassian.jira.bc.issue.DefaultIssueService.delete(DefaultIssueService.java:427) [classes/:?] at com.atlassian.jira.bc.issue.DefaultIssueService.delete(DefaultIssueService.java:403) [classes/:?] at com.atlassian.jira.web.action.issue.DeleteIssue.doExecute(DeleteIssue.java:23) [classes/:?] at webwork.action.ActionSupport.execute(ActionSupport.java:165) [webwork-1.4-atlassian-30.jar:?] at com.atlassian.jira.action.JiraActionSupport.execute(JiraActionSupport.java:63) [jira-api-8.13.1.jar:?] at webwork.interceptor.DefaultInterceptorChain.proceed(DefaultInterceptorChain.java:39) [webwork-1.4-atlassian-30.jar:?] at webwork.interceptor.NestedInterceptorChain.proceed(NestedInterceptorChain.java:31) [webwork-1.4-atlassian-30.jar:?]
When trying to individually index via scriptrunner:
com.atlassian.jira.index.IndexingFailureException: Indexing completed with 1 errors at com.atlassian.jira.index.AccumulatingResultBuilder$CompositeResult.await(AccumulatingResultBuilder.java:189) at com.atlassian.jira.issue.index.DefaultIndexManager.obtain(DefaultIndexManager.java:863) at com.atlassian.jira.issue.index.DefaultIndexManager.await(DefaultIndexManager.java:843) at com.atlassian.jira.issue.index.DefaultIndexManager.executeWithIndexLock(DefaultIndexManager.java:830) at com.atlassian.jira.issue.index.DefaultIndexManager.reIndexIssues(DefaultIndexManager.java:618) at com.atlassian.jira.issue.index.DefaultIndexManager.reIndexIssues(DefaultIndexManager.java:597) at com.atlassian.jira.issue.index.DefaultIndexManager.reIndexIssues(DefaultIndexManager.java:581) at com.atlassian.jira.issue.index.DefaultIndexManager.reIndexIssues(DefaultIndexManager.java:449) at com.atlassian.jira.issue.index.DefaultIndexManager.reIndex(DefaultIndexManager.java:547) at com.atlassian.jira.config.component.SwitchingInvocationHandler.invoke(SwitchingInvocationHandler.java:38) at com.sun.proxy.$Proxy17.reIndex(Unknown Source) at com.atlassian.jira.issue.index.IssueIndexManager$reIndex.call(Unknown Source) at com.onresolve.scriptrunner.canned.jira.admin.ReindexIssues$_doScript_closure1.doCall(ReindexIssues.groovy:103) at com.sun.proxy.$Proxy3986.accept(Unknown Source) at java_util_function_Consumer$accept.call(Unknown Source) at com.onresolve.jira.groovy.jql.AbstractPagerExecutor$_forEachInternal_closure2.doCall(AbstractPagerExecutor.groovy:68) at com.onresolve.jira.groovy.jql.AbstractPagerExecutor.forEachInternal(AbstractPagerExecutor.groovy:67) at com.onresolve.jira.groovy.jql.PagerExecutor.forEachIssue(PagerExecutor.groovy:26) at com.onresolve.scriptrunner.canned.jira.admin.ReindexIssues.doScript(ReindexIssues.groovy:99)
Hi Stephen,
have you already tried to Re-Index the instance?
Have you made sure Script Runner is on a compatible version after upgrade - along with all other Apps updated?
Have you per chance also had the time to look into log file for further errors despite the existing one with indexing?
Daniel
Yes :)
Even tried safe mode with the same results
Sad enough but I only can come up with a general article on how to debug indexing issues.
Whilst you are upgrading from an Long Term Support Release (they are known to be stable) to a more recent one you should not run into trouble in theory - but, anyway, further inspection now will be needed.
https://confluence.atlassian.com/jirakb/troubleshoot-a-reindex-failure-in-jira-server-429917142.html
When you say it is happening when trying to transition "some" issues - do they all have something in common? A special validator, condition, post function or so?
Let me post what Atlassian gave me that worked. :)
They attributed the bug to deleting issues while this wonky new version of 'Email this issue' is installed. Here's the fix via the DB.
Therefore, I would like to clear the table of that problematic Issue.
Please run this SQL query:
delete from issue_version where issue_id = 74030 and deleted = 'Y';
Once done, Kindly run a full Lock & Rebuild on the Index.
I believe that after disabling the app, new issues can be deleted.
Could you please check and confirm?
Also, for the old issues created before disabling/downgrading the add-on, the following SQL should be executed:
update issue_version set DELETED = 'N' where DELETED ='Y' and ISSUE_ID in (Select ID from jiraissue);
