Inherit field values from parent issue - how to?
Rumceisz
Hi All,
we would like to achieve that when creating subtasks for an issue the subtasks will inherit the value of a custom field and the fix version.
Is it possible?
Thanks in advance,
Rumi
RambanamP
October 20, 2013
check this plugin
https://marketplace.atlassian.com/plugins/com.atlassian.jira.copy-to-subtask-plugin
or you can write postfunction using groovy or java syntax
Christian Czaia [Decadis AG]
October 20, 2013
Hey Rumi,
I'd also check this plugin:
https://marketplace.atlassian.com/plugins/com.innovalog.jmwe.jira-misc-workflow-extensions
It used to be free (up to JIRA 5.2 I think) but I think it's really helpful.
Cheers
Rumceisz
thanks for the hints
Mikael Skogstrom
Thanks! We have the same request and the JIRA Misc seems easy enough to configure.
