×I'm using the greenhopper kanban board, and when I create a new issue it always ends up at the bottom. In the previous version of greenhopper with the task board, it would insert after whatever issue you were highlighed on. Is there any way to not insert an issue at the bottom, rather after a specific issue?
While I guess that is not possible, sending the story back to the top using the keyboard shortcut s+t may help you to manage the board better.
And it's a good feature request, I would recommend to file it at https://jira.atlassian.com
Rumour has it that the GreenHopper team has something like this in the oven right now :)
Thanks, I have opened an issue https://jira.atlassian.com/browse/GHS-7263. It would be great if that is already in the works.
