Insight Asset Management plugin- is it possible to keep the assets list view as default?
Fernando Nunez
December 13, 2018
every time I access to the Insight  assets admin page I have to change the type of view to List instead of the default Data view. I have also to check what columns I want to display in the list, because these settings are not being kept.
Is there a way to save these settings as default?
Insight plugin version: 5.7.5
Thank you in advance!
Fer.
Yinon Negev
December 13, 2018
Hola Fernando.
       The assets view is usually keeping the last settings you had, so when you revisit the same Object Type - the exact same view is kept, including IQL Filters.
This of course, requires cookies to be enabled... If you access through an Incognito / Private Mode Browser, settings won't be kept as well.
Yinon
Team Riada
Fernando Nunez
December 13, 2018
Hi Yinon,
ok, understood. Thank you for your reply and for the great job the Riada guys are doing with this plugin.
I would suggest (as a feature for future versions) that the Insight Jira administrator could configure the default view for all the assets.
Best regards,
Fernando.
Like Michael Canning likes this
