×We recently downloaded an evaluation version of JIRA and attempted to install it in our ESXi test environment. We chose CentOS 6.2 x64 as our OS of choice and we were able to complete the following installation steps without any problems:
1. Install CentOS 6.2 x64 (Minimum).
2. Assign static IP.
3. Add mysql, wget and nano to installation.
4. Download latest Linux x64 Jira to /tmp folder.
5. Execute chmod to make .bin file executable.
6. Run downloaded JIRA bin with default options.
7. Installation appears to complete successfully with a JIRA start message.
Even though the installation completed successfully, we are unable to load the JIRA portal at http://<ip>:8080
The log doesn't show any error messages and so we are clueless on what's causing the issue. We already validated the network settings and we are able to ping and telnet to the machine without any problems. As shown above the machine also doesn't have any problems reaching other systems. Since the server runs on an internal network there is no firewall between the server and the test workstation.
We included a screenshot from the ending of the log. We also scrolled up to the start event and there is no error message before the end of the log shown in the screenshot.
Based on the output of your iptables above.
Your server is only allowing tcp traffic in for you to ssh into the box.
You need to allow traffic in for port 8080 where your tomcat server is running. If you put a webserver in front of tomcat on the same box you'll need to open up that port too.
This reference (http://www.cyberciti.biz/faq/howto-rhel-linux-open-port-using-iptables/) seems good in telling you how to modify your iptables.
In your case you need to insert the following line in between line 6 and 7 in your output above...
-A RH-Firewall-1-INPUT -m state --state NEW -m tcp -p tcp --dport 8080 -j ACCEPT
Then restart and test your iptables configuration as described in the link above.
>We are simply getting a timeout message in Firefox. Is there anything else I should check?
Ah, I'll leave you to it then. Churn and timeout implies that the client can find the server, and get a "yes I'll talk to you" response, and then nothing more, which is usually a firewall issue. Disabling iptables kind of proves that.
I wouldn't disable it completely, I'd reconfigure, but check exactly what ports/protocols it's letting through and relax what is't blocking on the standard web-server ports for Tomcat/Jira.
Hi Cyril,
I did some testing and found that when I disable iptables it starts working. :)
Should we disable iptables on this machine or should we try to reconfigure it?
Thanks!!!
Hi Nic,
Thank you for your reply!
Hi Cyril,
I am not familiar with iptables beyond the knowledge that it is a firewall.
Here is the output for the first command:
ip_tables 17831 1 iptable_filter
I am guessing that the output above means that it is running.
Chain INPUT (policy ACCEPT) target prot opt source destination ACCEPT all -- anywhere anywhere state RELATED,ESTABLISHED ACCEPT icmp -- anywhere anywhere ACCEPT all -- anywhere anywhere ACCEPT tcp -- anywhere anywhere state NEW tcp dpt:ssh REJECT all -- anywhere anywhere reject-with icmp-host-prohibited Chain FORWARD (policy ACCEPT) target prot opt source destination REJECT all -- anywhere anywhere reject-with icmp-host-prohibited Chain OUTPUT (policy ACCEPT) target prot opt source destination
I believe that the relevant line is "ACCEPT tcp -- anywhere anywhere". Is that correct? Does that line mean that our system is accepting all incoming connections?
Thank you for taking the time to respond!
Have you checked the iptables configuration on your server?
First check if iptables is running...
# lsmod | grep ip_tables ip_tables 29288 1 iptable_filter x_tables 29192 6 ip6t_REJECT,ip6_tables,ipt_REJECT,xt_state,xt_tcpudp,ip_tables
Check the currently loaded rules if iptables is running...
# iptables -L
Chain INPUT (policy ACCEPT) target prot opt source destination RH-Firewall-1-INPUT all -- anywhere anywhere Chain FORWARD (policy ACCEPT) target prot opt source destination RH-Firewall-1-INPUT all -- anywhere anywhere Chain OUTPUT (policy ACCEPT) target prot opt source destination Chain RH-Firewall-1-INPUT (2 references) target prot opt source destination ACCEPT all -- anywhere anywhere ACCEPT icmp -- anywhere anywhere icmp any ACCEPT esp -- anywhere anywhere ACCEPT ah -- anywhere anywhere ACCEPT udp -- anywhere 224.0.0.251 udp dpt:mdns ACCEPT udp -- anywhere anywhere udp dpt:ipp ACCEPT tcp -- anywhere anywhere tcp dpt:ipp ACCEPT all -- anywhere anywhere state RELATED,ESTABLISHED ACCEPT tcp -- anywhere anywhere state NEW tcp dpt:ssh REJECT all -- anywhere anywhere reject-with icmp-host-prohibited
