Integrate JIRA and Confluence: Possible?
Ian Nájar
March 22, 2012
I have JIRA and Greenhopper in the same site: mycompany.atlassian.com
They work very well, but recently i sign up for Confluence. What if I set the access site to mycompany.atlassian.com? It will be integrated with JIRA products and share the same users?
If is possible, is there any change to change my url of my Confluence mycompany2.atlassian.com to the first one?
NOTE: The urls provided above are not valid, just examples.
Abdoulaye Kindy Diallo
March 22, 2012
You don't need two different URLs for that in OnDemand. In mycompany.atlassian.com you should have JIRA and Confluence (Wiki) at the same time. By default through crowd you can manage/share the same users. Finally, you have also the "Application Access" feature which allows to define who is going to access which application.
Hope that helps :)
Ian Nájar
March 22, 2012
Thanks, but know the questions is, if is still possible to change my current wiki address mycompany2.atlassian.com to mycompany.atlassian.com? because i already set it. Atlassian support its able to do this?
March 26, 2012
Changing domains is a Restricted Functions in Atlassian OnDemand. As per policy: "Currently we're unable to change your Atlassian OnDemand domain after the instance has been created. Please choose carefully when signing up." May be you could request for instance deletion if you don't need the content in order to sign up with a new domain name.
