Integrate Jira self-hosted and Stash with Confluence On Demand
Atlascloud Admin
June 11, 2014
1. Can self hosted Jira & Stash integrate with Confluence OnDemand?
2. Any feature or function on self hosted Jira & Stash would be restricted or unavailable due to integration with on Demand?
3. Can Jira & Stash run on virtual machine ( VMWARE ) for production enviroment?
ThiagoBomfim
June 12, 2014
Hi Wijaya,
1. Yes. Please refer to the Integrating JIRA OnDemand with Stash document.
2. Yes. It is described on the link above.
3. Regarding Stash, you can read Supported Platforms. There we state:
Although Stash can be run in virtualised environments, Atlassian is not yet able to provide technical support for performance-related problems in a virtualised environment. If you do chose to run Stash in a virtual machine, please ensure that you choose a VM with good IO throughput and sufficient free memory. See hardware requirements below.
Regarding JIRA, we state on the Supported Platforms:
  • Please read our Virtualizing JIRA (JIRA on VMware) guide for information on the required configuration of VMWare.
  • We are unable to provide any support for VMWare itself.
  • All of the operating systems listed in the 'Operating systems' rows above are supported for VMware.
I hope that helps.
Best regards,
Thiago Bomfim
Atlassian Support
Accounting Go2Group June 11, 2014
Yes, should be no and yes.
