Integration JIRA - GitHub: Could it be possible to create a label on GitHub automatically when moving an issue?
David Bermejo
June 2, 2015
Hi guys,
Kindly asking for help here smile We would like to keep track of our pull requests on GitHub adding labels there when we move our issues through the columns on our board.
For example, let's say that we move an issue from "In progress" to "In code review" on the JIRA board. We would like to get the label ":review" applied on GitHub automatically. Do you know if the integration between the two tools allows this functionality?
Thanks!
David Bermejo
June 2, 2015
Hi Teilor. Thanks for your answer, I will take a look! Cheers!
Deleted user September 12, 2017
Hi David,
I want to do just the same; did you find a way to implement that you could share?
Have a good day,
teilor_soares
June 2, 2015
I believe JIRA does not have this option using the default integration, but you may be able to achieve what you want using Webhooks in the workflow transitions.
Cheers!
Teilor
