×Hi,
I wanted to know if there could be a way that pull request to BitBucket be tied to the Jira ticket approval ? (Push of code possible only if the jira ticket is approved)
Sowmya
Yes, it is possible, but you need an app for it. Jira hooks for Bitbucket allows you to use a JQL to make sure the issue is in the correct status before you can push it. There might be other apps on Marketplace that can do the same.
