I'm using the Project Configurator add-on to import a project backup to a dev instance but I keep getting these errors:
I've tried changing the filename, unzipping the file and importing from the extracted file, and removing and copying over again but nothing seems to be working. Some clarification on what I'm doing wrong would be greatly appreciated.
We just had the same issue and realized that since this is a Project Configurator backup, you have to go to Add-ons -> Project Configurator -> Import Complete Project instead of using the core Jira backup import (System -> Project Import).
Thanks, Savannah! Looks like I can import projects through Project Configurator.
Hi @Rehnuma Noor !
Like @Savannah Ritter mentioned, please use the Project Configurator menu in your Jira Administration Add-ons page. If you have any questions or need guidance, don't hesitate to contact our Support here Project Configurator Support.
We will assist you asap.
Jannina
