I installed Jira yesterday and it work well, but when I come back today I got the follwoing error in the browser:
Exception thrown during upgrade: Invalid column name 'creator'. java.sql.SQLException: Invalid column name 'creator'.
followed by the module stack
I try to start Jira with the user credential I configured while installing Jira. This account works and I can work in Jira until this error happened.
I also try to use the sa account in case it is a rights problem, same error.
I call the start-jira.bat with -Djira.autoexport=false, doesn't change anything.
Jira is running on
Windows Server 2008 english
MS SQL 2008 english
Collation is SQL_Latin1_General_CP1_CS_AS
So, how to get rid of this error?
Michael
Here is what I see in the console:
JIRA 6.2.4 build: 6261 started. You can now access JIRA through your web browser.
2014-05-14 13:36:00,364 localhost-startStop-1 INFO [atlassian.jira.upgrade.UpgradeManagerImpl] Detected that an upgrade is needed; existing data at build 6207
2014-05-14 13:36:00,367 localhost-startStop-1 INFO [atlassian.jira.upgrade.UpgradeManagerImpl] Exporting the existing data..
2014-05-14 13:36:02,076 localhost-startStop-1 INFO [jira.bc.dataimport.DefaultExportService] Data export completed in 1624ms. Wrote 889 entities to export in memory.
2014-05-14 13:36:02,078 localhost-startStop-1 INFO [jira.bc.dataimport.DefaultExportService] Attempting to save the Active Objects Backup
2014-05-14 13:36:03,052 localhost-startStop-1 INFO [jira.bc.dataimport.DefaultExportService] Finished saving the Active Objects Backup
2014-05-14 13:36:03,059 localhost-startStop-1 INFO [atlassian.jira.upgrade.UpgradeManagerImpl] Exported pre-upgrade data to:C:\Atlassian\Application Data\JIRA\export\jira_autoexport_20140514_133600.zip
2014-05-14 13:36:03,060 localhost-startStop-1 INFO [atlassian.jira.upgrade.UpgradeManagerImpl] ___ Performing Upgrade ____________________
2014-05-14 13:36:03,464 localhost-startStop-1 INFO [atlassian.jira.upgrade.UpgradeManagerImpl] Performing Upgrade Task: Populates the issue creator field
2014-05-14 13:36:03,469 localhost-startStop-1 ERROR [atlassian.jira.upgrade.UpgradeManagerImpl] Exception thrown during upgrade: Invalid column name 'creator'.
at net.sourceforge.jtds.jdbc.SQLDiagnostic.addDiagnostic(SQLDiagnostic.java:368)
at net.sourceforge.jtds.jdbc.TdsCore.tdsErrorToken(TdsCore.java:2820)
at net.sourceforge.jtds.jdbc.TdsCore.nextToken(TdsCore.java:2258)
at net.sourceforge.jtds.jdbc.TdsCore.getMoreResults(TdsCore.java:632)
at net.sourceforge.jtds.jdbc.JtdsStatement.processResults(JtdsStatement.java:584)
at net.sourceforge.jtds.jdbc.JtdsStatement.executeSQL(JtdsStatement.java:546)
at net.sourceforge.jtds.jdbc.JtdsPreparedStatement.executeUpdate(JtdsPreparedStatement.java:506)
at org.apache.commons.dbcp.DelegatingPreparedStatement.executeUpdate(DelegatingPreparedStatement.java:105)
at com.atlassian.jira.upgrade.tasks.UpgradeTask_Build6208.copyReporterToCreator(UpgradeTask_Build6208.java:69)
at com.atlassian.jira.upgrade.tasks.UpgradeTask_Build6208.doUpgrade(UpgradeTask_Build6208.java:51)
at com.atlassian.jira.upgrade.UpgradeManagerImpl.doUpgradeTaskSuccess(UpgradeManagerImpl.java:685)
at com.atlassian.jira.upgrade.UpgradeManagerImpl.runUpgradeTasks(UpgradeManagerImpl.java:534)
at com.atlassian.jira.upgrade.UpgradeManagerImpl.doUpgrade(UpgradeManagerImpl.java:463)
at com.atlassian.jira.upgrade.UpgradeManagerImpl.doUpgradeIfNeeded(UpgradeManagerImpl.java:405)
at com.atlassian.jira.upgrade.UpgradeManagerImpl.doUpgradeIfNeededAndAllowed(UpgradeManagerImpl.java:340)
at com.atlassian.jira.upgrade.UpgradeLauncher.checkIfUpgradeNeeded(UpgradeLauncher.java:106)
at com.atlassian.jira.upgrade.UpgradeLauncher.start(UpgradeLauncher.java:54)
at com.atlassian.jira.startup.ActiveServicesLauncher.start(ActiveServicesLauncher.java:42)
at com.atlassian.jira.startup.DefaultJiraLauncher$3.run(DefaultJiraLauncher.java:132)
at com.atlassian.jira.config.database.DatabaseConfigurationManagerImpl.doNowOrEnqueue(DatabaseConfigurationManagerImpl.java:317)
at com.atlassian.jira.config.database.DatabaseConfigurationManagerImpl.doNowOrWhenDatabaseActivated(DatabaseConfigurationManagerImpl.java:211)
at com.atlassian.jira.startup.DefaultJiraLauncher.postDbLaunch(DefaultJiraLauncher.java:118)
at com.atlassian.jira.startup.DefaultJiraLauncher.access$100(DefaultJiraLauncher.java:32)
at com.atlassian.jira.startup.DefaultJiraLauncher$1.run(DefaultJiraLauncher.java:81)
at com.atlassian.jira.util.devspeed.JiraDevSpeedTimer.run(JiraDevSpeedTimer.java:34)
at com.atlassian.jira.startup.DefaultJiraLauncher.start(DefaultJiraLauncher.java:76)
at com.atlassian.jira.startup.LauncherContextListener.contextInitialized(LauncherContextListener.java:54)
at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4939)
at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5434)
at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:150)
at org.apache.catalina.core.ContainerBase$StartChild.call(ContainerBase.java:1559)
at org.apache.catalina.core.ContainerBase$StartChild.call(ContainerBase.java:1549)
at java.util.concurrent.FutureTask.run(FutureTask.java:262)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
at java.lang.Thread.run(Thread.java:745)
2014-05-14 13:36:07,494 localhost-startStop-1 INFO [ext.bamboo.service.PlanStatusUpdateServiceImpl] Job 'com.atlassian.jira.plugin.ext.bamboo.service.PlanStatusUpdateServiceImpl:job' scheduled to run every 60000ms
2014-05-14 13:36:07,497 localhost-startStop-1 INFO [plugins.dvcs.scheduler.DvcsScheduler] DvcsScheduler start planned at WedMay 14 14:04:08 CEST 2014, interval=3600000
2014-05-14 13:36:08,995 localhost-startStop-1 INFO [jira.whatsnew.listeners.WhatsNewUpgradeFinishedListenerImpl] Enabling show-whats-new-flag for all users
2014-05-14 13:36:09,012 localhost-startStop-1 INFO [atlassian.jira.scheduler.JiraSchedulerLauncher] JIRA Scheduler not started: Johnson events detected.
2014-05-14 13:36:09,105 Modification Check:thread-1 INFO [atlassian.jira.startup.JiraStartupLogger]
___ Modifications ___________________________
Modified Files : jira-application.properties
Removed Files : None
Mai 14, 2014 1:36:09 PM org.apache.coyote.AbstractProtocol start
INFO: Starting ProtocolHandler ["http-bio-8080"]
Mai 14, 2014 1:36:09 PM org.apache.catalina.startup.Catalina start
INFO: Server startup in 74650 ms
The first question that springs to mind is "why does it think it needs to do an upgrade"?
Where did you get the data in there, and what version did it come from?
Thanks, that helps. I set it to Latin1_General_CI_AS and it worked.
I've just run into this problem aswell.
Setting the database language to SQL_Latin1_General_CP437_C1_A1 allowed the startup to get past the error you have shown.
