Invalid username error on importing project from Fogbugz on Demand
Gottfried Theimer
December 19, 2018
I am evaluating Jira as potential migration target coming from FogBugz. Unfortunately, importing a project from FogBugz on Demand, following the instructions given by Atlassian, fails and produces the following log:
2018-12-19 10:16:17,520 INFO - Import started by gtheimer using com.atlassian.jira.plugins.importer.imports.fogbugz.hosted.FogBugzHostedDataBean
2018-12-19 10:16:17,537 INFO - ------------------------------
2018-12-19 10:16:17,537 INFO - Importing: Users
2018-12-19 10:16:17,545 INFO - ------------------------------
2018-12-19 10:16:17,545 INFO - Only new items will be imported
2018-12-19 10:16:17,845 WARN - Invalid username '' - You must specify a username.
2018-12-19 10:16:17,854 WARN - Invalid username '' - You must specify a username.
2018-12-19 10:16:17,859 WARN - Invalid username '' - You must specify a username.
2018-12-19 10:16:17,866 WARN - Invalid username '' - You must specify a username.
2018-12-19 10:16:17,889 WARN - Invalid username '' - You must specify a username.
2018-12-19 10:16:17,890 WARN - Invalid username '' - You must specify a username.
2018-12-19 10:16:17,897 WARN - Invalid username '' - You must specify a username.
2018-12-19 10:16:17,903 WARN - Invalid username '' - You must specify a username.
2018-12-19 10:16:17,904 WARN - Invalid username '' - You must specify a username.
2018-12-19 10:16:17,918 WARN - Invalid username '' - You must specify a username.
2018-12-19 10:16:17,922 WARN - Invalid username '' - You must specify a username.
2018-12-19 10:16:17,947 WARN - Invalid username '' - You must specify a username.
2018-12-19 10:16:17,948 ERROR - Cannot perform import due to 12 invalid usernames
com.atlassian.jira.plugins.importer.external.InvalidUsernamesException: Cannot perform import due to 12 invalid usernames
	at com.atlassian.jira.plugins.importer.external.ExternalUserUtils.checkInvalidUsernames(ExternalUserUtils.java:134)
	at com.atlassian.jira.plugins.importer.external.ExternalUserUtils.prepareUsers(ExternalUserUtils.java:107)
	at com.atlassian.jira.plugins.importer.imports.importer.impl.DefaultJiraDataImporter.importUsers(DefaultJiraDataImporter.java:564)
	at com.atlassian.jira.plugins.importer.imports.importer.impl.DefaultJiraDataImporter.doImport(DefaultJiraDataImporter.java:345)
	at com.atlassian.jira.plugins.importer.imports.importer.impl.ImporterCallable.call(ImporterCallable.java:26)
	at com.atlassian.jira.plugins.importer.imports.importer.impl.ImporterCallable.call(ImporterCallable.java:15)
	at com.atlassian.jira.task.TaskManagerImpl$TaskCallableDecorator.call(TaskManagerImpl.java:458)
	at com.atlassian.jira.task.TaskManagerImpl$TaskCallableDecorator.call(TaskManagerImpl.java:426)
	at java.util.concurrent.FutureTask.run(FutureTask.java:266)
	at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
	at com.atlassian.jira.task.ForkedThreadExecutor$ForkedRunnableDecorator.run(ForkedThreadExecutor.java:216)
	at java.lang.Thread.run(Thread.java:748)
2018-12-19 10:16:18,321 INFO - No issues need to be reindex
Any hint how to solve this problem would be awesome.
Nicholas Carter
September 23, 2019
Had the same issue. Potentially users in Fogbugz with no email address or users with duplicate emails.
Had to get these users from the API.
Ekta Soni
August 13, 2019
Even I too facing same problem . If someone has resolved this issue please help .
Vitaliy Minakov
May 13, 2019
I'm having the same problem- any resolution?
