×Hi Team,
Currently we are using using Testopia and Bugzilla for Test Case and Defect Management. Would like to know whether Integration is possible between JIRA and Testopia or Bugzilla.
Can integration between Testopia and Jira be possible? Eg. When a Test Case fails in Testopia, can the defects be raised in Jira by adding a plugin?
A replacement of Bugzilla by JIRA?
Depending on what you mean by integration. Can you give more details on what integration you need ?
