Is Jira 5.2.8 supportable with Oracle 12c
Ashutosh pandey March 20, 2017
Niclas Sandstroem
March 20, 2017
Hi Niclas ,
Thanks for your reply , we are migrating our database to Oracle 12 c .
Do you have any clue that what will happen when this process is completed ?
Thanks in advance
Ashutosh
Niclas Sandstroem
March 20, 2017
It's hard to speculate do a lot of testing!
Nic Brough -Adaptavist-
March 21, 2017
I suspect it's going to fail.  The problem is that you're going to need a slightly more recent jdbc driver than works on the version of Java you need to run for JIRA 5.2.
It might work, but you'll need to do extensive testing with a mix of java and jdbc drivers that are not expected to work properly.
I would not bother.  I would upgrade JIRA to a supported version.
Sachin March 20, 2017
No, Its Not
