Is SQL Server 2012 SP1 - 64bit compatible with Jira 7.3.4?
Deniz Oğuz - The Starware
April 12, 2017
On supported platforms section I have found it supports SQL Server 2012. Is this means SP1 is also supported? We are getting "Database Locked" exception when trying to install JIRA using a newly installed database.
Thanks.
Dave Theodore [Coyote Creek Consulting]
They haven't updated the Supported Platforms page for 7.3, so I would open a support issue to be sure.
Neha
April 12, 2017
htghj
