Is Subtask and Child Issue same?
Vineela AK
Is Subtask and Child issue same in Jira? I am trying to create a subtask and i don't see a subtask. Can we create a sub task for To Do, In Progress?
Fabio Racobaldo _Catworkx_
Hi @Vineela AK ,
welcome to the Atlassian community!
Please verify that sub-task issue type has been defined in your project Issue Type scheme. Moreover subtask creation is status indipendent so it could be created in each status.
Fabio
John Funk
Hi Vineela - Welcome to the Atlassian Community!
It depends somewhat on the context, but yes a sub-task is considered to be the child of it's parent issue.
Now having said that, you might need to enable the ability to create Sub-tasks. Follow the guidance here to be sure it is enabled.
https://support.atlassian.com/jira-cloud-administration/docs/configure-sub-tasks/
Ashley Hudson
January 18, 2023
Heya @Vineela AK
In terms of the differences between the subtask and the child issue, there perhaps is a miss-conception here. So the issue type "Sub-Task" is seen to be the lowest issue in the issue hierarchy, so in terms of creating another child sub-task this is not possible! In jira, we use the following hierarchy to work on issues (generically for most projects):
Epic -> Story -> Task -> Sub-Task
I'd advise that you create a task and link the relevant sub-task (child tickets) to the task ticket!
Kind Regards,
Ashley Hudson
Nic Brough -Adaptavist-
January 19, 2023
I'm afraid that's wrong.  You can't do that in Jira.
The Jira hierarchy is Issue -> Sub-task.
If you have Jira Software, then you get  Epic -> Issue -> Sub-task.
To get a bigger hierarchy, you need to add an app to do it - Atlassian's own Advanced Roadmaps, Tempo's Structure, my own Adaptavist's Hierarchy, JXL, Links Hierarchy and so on.  A lot of these work off issue links - Jira doesn't itself understand the hierarchy that the apps show, but it does understand the linking.
Like John Funk likes this
FREE
